12-18-2025
22:08
03:34
12-18-2025
22:08
03:34
The display is barely visible.
Sometimes it is bright fof a fraction of seconds.
Hi there, @stunning_user. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the image attached. I'm sorry to hear that the screen of your Versa 4 is too dim. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend checking the brightness settings on your Versa 4. For more information, see Change screen & brightness settings
If the screen of your Versa 4 is still dim after adjusting the brightness settings, please try the following:
If the above doesn't work, please restart your Fitbit device once again. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
