11-24-2023 09:44 - edited 11-25-2023 10:56
not really much to say, except that it just boots up again after going through the menu to shut down.
Author Edit: the subject was not clarified. the Problem is that if I try to shut it down through the menu, it just boots up, rather than staying off like it should.
11-24-2023
19:57
13:00
11-24-2023
19:57
13:00
Hi @My1xT - I had this too, if it stays up long enough, try changing clock face from the Fitbit App. It may help, as sometimes shutdown while on charge will do.
A factory reset might be the only other option but it may come back again. If you start a factory reset leave the watch for 5 minutes to allow time to complete.
11-25-2023 01:52
11-25-2023 01:52
does a sideloaded clockface get deleted in the process and I have to reload from PC? or can I change back to it from the app?
11-25-2023 02:24
