Versa 4 is draining so fast
My Fitbit versa 4 is draining so fast. I've had it for quite some time. I read somewhere else that I should turn off the Bluetooth at night, will I still be able to get sleep data, if I turn it on in the morning?
Any recommendations of what to do to help it not drain so fast besides changing the clock face which I already did years ago.
1 REPLY 1
Welcome to the Fitbit Community! It's great to have you here @gatens!
I appreciate the information that you've shared about the battery draining situation that you've been having with your Versa 4.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users.
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
I'll be around.
