08-22-2023
15:41
03:54
08-22-2023
15:41
03:54
I walked 2.4 miles. Fitbit 4 registered 2 miles. How to fix?
Welcome to the Fitbit community, @Nelle2823!
In order to give you more precise results on distance tracking your Versa 4 needs to know your stride length. To get more insights on this, I'd suggest having a look at "How does my Fitbit device calculate distance traveled?" and "Can I change my stride length in my Fitbit account?" following the link below.
How does my Fitbit device calculate my daily activity?
Hi there, @Nelle2823. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
As @Talahthas has mentioned, Fitbit devices use the formula below to calculate distance. Your stride length is determined by your height and sex. Steps x Stride Length = Distance Traveled
Please note when you track an activity with GPS, your device calculates your distance using GPS data rather than steps. If you begin moving before you get a GPS signal, your device calculates distance using your steps until GPS connects.
To update your stride length, track a run with GPS or measure your stride length manually. For more information, see Can I change my stride length in my Fitbit account?
For more information about GPS, see How do I use GPS on my Fitbit device?
