05-28-2024
12:41
12:48
05-28-2024
12:41
12:48
My sleep score isi very random. Some days it works, most days it's blank. What can I do to fix this??
Thanks
05-28-2024 14:11
05-28-2024 14:11
Same here and when it does, whomever they have designing their new app needs sacking as the replacement data is illegible and the most non-user friendly data ever….as with the activity data….thanks Fitbit!
05-31-2024 04:09
05-31-2024 04:09
Same here. It never gives me a score on my phone. I always have to get it from the app. Makes no sense.
Best Answer06-01-2024 09:38 - edited 06-01-2024 09:39
Welcome back to the community @harristom @MelBee12 @AliP369
Thank you for taking the time to share the experience with Versa 4 and for all the steps that you already did in order to fix it. I'm sorry to know about the inconvenience.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
The Versa 4 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same situation.
In case the inconvenience is related to the Fitbit app, please try the following as well:
