12-19-2024
09:59
03:34
12-19-2024
09:59
03:34
I have been a fitbit user since 2016 and generally very happy. However since this update my watch has not been working properly. It first started with just a black screen with the time(instead of my background) the screen was unresponsive, then would go black. The watch is still on, but does not track anything or turn on until I would connect it to the charger.
Sometimes inbound.habe hold the power button and would get a fli sering fitbit logo, then a red X. After leaving it on a charge it would work again. But as soon as I took it off the charger it would.go black.
Currently my batter is at 100% but I can not use my watch nor is it tracking anything.
I have tried every step as per the forums and groups and none of them have worked.
My watch is less than 2 years old and is in excellent condition. I have seen that multiple people are experiencing the same issue.
Is there a fix?
12-23-2024 06:23 - edited 12-23-2024 06:23
Hi there @CoachDubya! A warm welcome to the Fitbit Community!
Thank you so much for letting us know about this situation and for all your efforts.
Have you already tried to change the clock face? If not try to change it and choose one developed by Fitbit.
Let us know how it goes.
12-23-2024 20:37
12-23-2024 20:37
Yes i have as well as a reset. This all started as of the update. When will this be fixed?
12-24-2024 06:05
12-24-2024 06:05
Hi @CoachDubya!
Thanks for your answer and efforts!
Since you have tried the steps and your Versa 4 still doesn't work, I need more information from you, which is best shared privately. I am sharing a link to a form for you to fill out here.
This form is for you only, so let me know when you have completed it.
