Versa 4 is taking too long to sync
ANSWERED
Why dose my fit bit take a longtime to sync or default to yesterdays sync
1 BEST ANSWER
Accepted Solutions
Hi there, @Kidney2023. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
If you continue having syncing difficulties after following @Talahthas's recommendations, please try the following:
  • Unpair your Versa 4 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 4.
  • If there is no connection, restart your Versa 4.
  • Set up notifications again.
  • Once your Versa 4 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
4 REPLIES 4
Welcome to the Fitbit community, @Kidney2023!
Sad to hear that you're having issues syncing your Versa 4. As a first step to hopefully help you, please have a closer look here:
Why won't my Fitbit device sync?
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
i have sorted it out thank you for your advice
Hello there, @brotell. Thanks for stopping by in the Fitbit Community Forums. I'm glad to hear your issue got solved.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
