08-09-2023
08:43
04:01
08-09-2023
08:43
04:01
Stopped working. Last thing it did was charge up showed blue startup and then a blank screen. Nothing since. No charge no startup.
Hi there, @Reneei. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
As a first approach, please follow @Talahthas' tips and recommendations as it seems like your Versa 4 ran out of battery. If afterwards you keep getting the Fitbit logo on the screen, please try the steps below:
If you can't get started with your Versa 4, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Welcome to the Fitbit community, @Reneei!
Sad to hear that your Versa 4 isn't working as expected. To hopefully get things fixed, please first make sure that your device really is able to get charged by having a closer look here:
Why isn't my Fitbit device's battery charging?
I'd also recommend trying to restart your Versa 4 by holding it's button for around 10 seconds until you'll see the Fitbit logo on it's display. Keep in mind though that your device needs at least a little bit of charge for that.
I'll keep my fingers crossed.
