06-12-2023
13:41
18:22
AndreaFitbit
06-12-2023
13:41
18:22
AndreaFitbit
my versa is not charging properly
It's taking 7 hours to charge keep buzzing on and off the time is gone out of sync
Moderator edit: updated subject for clarity and format.
Hi @Blessedlady31 - try restarting the watch by holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Check the terminals are clean and try a different power source.
Also check the syncing which sets the time correctly, see Why won't my Fitbit device sync?
You can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support for more specific information.
If the watch is faulty it can be replaced under warranty.
Hi @Blessedlady31. A warm welcome to the forums.
Thanks for sharing the details regarding your Versa 4.
Please, let us know if you are still experiencing the inconvenience with charging your device.
Here are the tips in order to identify a reason why your device is not able to sync.
