07-09-2024
16:00
04:33
07-09-2024
16:00
04:33
Why does my fibit make a vibration noise when charging? How to turn it off
Hi @Just2fab - normally a vibration is associated with poor charging (and a popup on the display), try cleaning the contacts or even changing power source.
In case it comes from a clock face try changing to another while charging.
If it is really annoying, sync before charging, place on charge, then in watch Settings do a Shutdown.
If you use the SimpleClockPro clock face for charging it will tell you when it will be charged and you can come back and turn it on then to check, by pressing the button a few seconds.
Hi there, @Just2fab. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I understand your concern, we're here to help you!
In addition to the great tips recommended by @Guy_, since this is happening when charging your Inspire 3, please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
@Just2fab Awesome! I'm happy to hear that your issue is now solved.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
