03-29-2024 02:32
03-29-2024 02:32
Hi, when I put my 2 month old Versa 4 on charge, it moves between various screens.
I have done 2 hard resets but it is still doing it.
Best Answer03-29-2024 05:33
03-29-2024 05:33
Hi @Slam1 - some clock faces may detect and respond to charging intentionally, I know SimpleClockPro does in order to keep you updated on progress and tell you by when your watch will be charged. Others may have different features
If you don't want the feature change to another clock face and also be careful when handling the watch when you put it on charge to avoid accidentally changing settings, long light press can also initiate the clock change feature built in to the watch.
Best Answer03-29-2024 10:34
03-29-2024 10:34
