02-25-2025
07:39
08:27
DavidFitbit
02-25-2025
07:39
08:27
DavidFitbit
I bought a Verse 4 yesterday and everything was working. Today my calls now text are coming through.
they are not coming through.*
Moderator edit - updated subject for clarity &they are not coming through.
Best Answer02-25-2025 09:03
02-25-2025 09:03
02-25-2025 09:03
02-25-2025 09:14
02-25-2025 09:14
Best Answer02-26-2025 09:26
02-26-2025 09:26
Hi @Guy_ and welcome @mcr72 to the Fitbit Community! It's great to have you here!
As @Guy_ said, from the clock face swipe down to check quick settings as shown below
The first two icons are Do Not Disturb and Sleep Mode. When the do not disturb setting is on notifications are muted. When the sleep mode setting is on notifications are muted.
07:56
08:17
DavidFitbit
02-27-2025
07:56
08:17
DavidFitbit
Ok. I see this and my Fitbit looks exactly like the picture. What now?
I've got it. Thank you for your help
Moderator edit: merged reply
Best Answer03-01-2025 09:24
03-01-2025 09:24
I’ve done this and I still don’t get my notifications.
Best Answer03-01-2025 11:52
03-01-2025 11:52
Hi @J.hernandez, thank you for your response.
I'm glad to help you with your notifications.
Just to make sure, have you already set notifications by folowing the instructions in our help article How do I get notifications from my phone on my Fitbit device? > How do I set up notifications? ?
If yes, then take a look at the tips suggested in the section "Why are notifications delayed or missing?" contained in the same help article.
17:56
06:39
MarioSFitbit
03-01-2025
17:56
06:39
MarioSFitbit
My Versa 4 has won't sync since yesterday too. I have deleted the app and reinstalled it without luck. Versa 4 had issues with syncing in 2023 and I starting to believe it's going to need another update to fix it. Hopefully it don't take as long this time to get the fix and it did then.
Moderator edit - word choice
