01-29-2025
12:53
16:24
ManuFitbit
01-29-2025
12:53
16:24
ManuFitbit
Today my sleep tracker looks totally different (no longer shows light, deep & rem, but instead just shows awake, restless & asleep) and did not provide a sleep score. Is this a recent update or a bug on my app? If it’s no longer giving a sleep score, I wish the dash would go away on my watch bc it’s driving me nuts not populating.
Moderator edit: clarified subject.
Hi @Kmreed. Welcome to the forums.
Thank you for sharing the inquiry regarding your Versa 4.
Keep in mind that you must see sleep stages in order to see a sleep score. As you confirmed, in this case you see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Versa 4 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.In case the problem is related to the Fitbit app, please try the following as well:
