02-12-2025
01:02
06:50
DavidFitbit
02-12-2025
01:02
06:50
DavidFitbit
My Samsung s24 will not connect to versa 4 calls it is however paired blue tooth just says cannot connect
Best Answer02-12-2025 06:26
02-12-2025 06:26
Hi @Adamspat Welcome to the Fitbit Community! It's great to have you here!
Let me help you with the on-wrist phone calls with your Versa 4.
Just to make sure, there is an additional setup for this feature. If you didn’t set up on-wrist calls when you connected your Fitbit device to your account, from the Today tab in the Fitbit app on your phone, tap Devices > Versa 4 > On-Wrist Calls. Then, follow the instructions below to set up on-wrist calls.
Tap each setup requirement, and follow the on-screen instructions to accept and turn on the necessary pairing permissions and requests.
Best Answer02-15-2025 07:32
02-15-2025 07:32
Hi,I followed your advice and wrist calls worked,but when I opened the Fitbit app later in the day it said tap to fix and I had to do it all again. Is this correct.
