01-13-2024 13:37
01-13-2024 13:37
Versa 4 recorded 107,000 steps today. How do I fix it for today & future as obviously I didn't walk that much....should be about 4,000
Best Answer01-13-2024 23:14
01-13-2024 23:14
@JewelsG33.48 is your phone Android or iOS. I'm on Android.
Let's check and see if we need to remove the phone from your fitbit app..
First we will open the Fitbit app and tap in the top left
On the next page. Do you see a last sync under the phone.
If you see add phone, your phone is not connected.
If you do see a last sync, tap the phone Icon
Now tap disconnect device.
I believe this is why you are getting a lot of steps.
If so, then once you do the above steps let us know
Best Answer01-13-2024 13:43
01-13-2024 13:43
To prevent happening again:
On phone app from Today screen, tap battery icon at top left to go to connected devices screen, remove your phone as a fitbit device.
Too late to fix.
Best Answer01-13-2024 13:49
01-13-2024 13:49
Best Answer01-13-2024 16:24
01-13-2024 16:24
Phone connected as a Fitbit device is just to have it use your phone to count steps when you are not wearing your Fitbit. That has nothing to do with the normal use of your phone that everyone needs to sync their data. If you are counting on your phone to count steps, then disregard what I said above, but I believe it have a bug. Everyone who I have come across getting tens of thousand steps added all at once seems to have their phone connected a a fitbit device, often without even realizing it. Again that is not needed for normal everyday usage of the phone app and syncing. I wish I could think of fitbit's term for using the phone to count steps. Again if you are relying on that, then forget my advise.
Best Answer01-13-2024 17:30
01-13-2024 17:30
Hi @JewelsG33.48 — @JohnnyRow ’s response is spot-on. I would add that there are some repetitive things we do that can add extra steps - for example, I play guitar with my fitbit on the same arm I strum with - and it counts the strums as steps! I know you probably don’t strum a guitar 107,000 a day, but it’s something else to think about.
Best Answer01-13-2024 17:46
01-13-2024 17:46
Best Answer01-13-2024 19:05
01-13-2024 19:05
Used to be called MobileTrack, for taking steps from phone (which I think seems to have a massive bug in it) but seems they might have dropped the term.
Best Answer01-13-2024 19:26
01-13-2024 19:26
I only have versa synced to fitbit app nothing else added to it for mobile tracking. Everything else I saw says once it cycles through a sleep it should be fine...if not it's a bigger problem.
Best Answer01-13-2024 22:49
01-13-2024 22:49
I really don't think we are communicating clearly on this, but if you are satisfied so am I.
01-13-2024 23:14
Best Answer01-14-2024 07:53
01-14-2024 07:53
