08-12-2023
16:59
12:07
08-12-2023
16:59
12:07
Mosy of my display settings are grayed out. Is this a software issue or am I missing something?
Best Answer08-12-2023 18:44
08-12-2023 18:44
Hi @KCHOLLO - this is normal if you have the watch in sleep mode.
Pull down on the watch face to get to Quick Settings and turn off all the icons and then settings will be normal.
It's a good idea to schedule watch sleep mode in the settings Quiet modes, as this stops it coming on at night or disturbting you with notifications and dims it which also saves battery.
If you need to see the time at night push the button or double tap it.
Best Answer08-12-2023 19:15
08-12-2023 19:15
You are brilliant, thank you! Worked like a charm- appreciate!
