Versa 4 won't turn on or charge
Had versa 4 a week. Watch will not charge & screen is dark
5 REPLIES 5
Hi @Miche69 - try using a PC port as the power source and after 10 minutes hold the button for 10 seconds till it vibrates and the logo appears and wait for it to startif it hasn't started by itself.
If that doesn't work check How to check charge cable - Sense 2/Versa 4 won't charge, won't start or blank screen
Hi there, @Miche69. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4. @Guy_ Thank you so much for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Same Mine, I  have followed all the instructions from services,  but still the same, it's just completed 1 year warranty
Hi @mendiskumara196 - do you have a Versa 4, if so it is still under warranty as it was only released in September 2022.
It's Versa 3, Purchased from Noel Leeming- St lucks Stores IN New Zealand.
