01-18-2023
14:53
08:58
01-18-2023
14:53
08:58
Update: had to unpair from app, turn off watch then redo all over again and finally got it fixed.
Versa 4 not syncing since new IOS update 16.2. I’ve restarted the phone twice, force closed the app multiple times; phone and device are up to date. Anyone else having trouble? Thanks
Thanks for the info. I had already gone through most of these steps before coming to the forum Was finally able to get it to sync again as noted in my update above. Sometimes the iOS updates really wreak havoc with our devices. It's nice to know there are others here to help when the usual google searches don't work. Thanks again!
Hi @Beachgirl9 - here is a help on the issue Why won't my Fitbit device sync? there might be something there that helps.
02-20-2023
18:01
08:04
02-20-2023
18:01
08:04
Hi there, @Beachgirl9. @Guy_ Thanks for your great help!
@Beachgirl9 I'm glad your Versa 4 is syncing correctly and thanks for sharing the steps that worked for you. This is great news and I'm going to mark your post as the Best Answer to help other members experiencing similar issues.
