04-13-2024
16:50
05:10
04-13-2024
16:50
05:10
My watch would vibrate whenever I received a phone call, now it does not.
How may I reactivate that feature?
04-14-2024 03:22 - edited 04-14-2024 03:26
@TamiFloyd2 From the Today screen, tap the icon with the battery % in the upper left hand corner, then tap on your Versa 4, then tap Notifications and make sure Calls are toggled on (green). If that doesn't work, then make sure your Versa 4 isn't in Do Not Disturb Mode -- Swipe down from the top of the device and make sure the icon in the upper left hand corner is greyed out (it looks like a circle with a line in it).
And after all of that, if you are still not receiving notifications, I'd suggest restarting the device.
04-14-2024 17:15
04-14-2024 17:15
Thank You, I got It!
