12-11-2022
08:49
10:28
12-11-2022
08:49
10:28
Versa 4 stops while in a workout, then starts back with a “welcome back” message
Best Answer12-11-2022 09:18
12-11-2022 09:18
Hi @Yorkiekids2 - if you are left handed it's possible you pushed and held the button accidentally which may have caused it to restart.
12-11-2022 12:34
12-11-2022 12:34
Best Answer12-13-2022 04:56 - edited 12-13-2022 04:56
In addition to that, it's totally stopped recording all sleep activity. Come on Google step up and fix these things.
Best Answer12-13-2022 08:42
12-13-2022 08:42
@Yorkiekids2 If you are wearing it on your left wrist and bending your wrist, it is very possible like @Guy_ suggested that you are pausing your workout which is causing the gap. This is the problem with a button and it was an issue on the Versa and Versa 2 devices as well. A lot of people didn't like the haptic feedback "button" on the Versa 3, so Fitbit/Google brought the button back to the Versa 4. You'll just have to watch your wrist movements a bit more, there's not much else that can be done since there is a button that can potentially pause or stop your workouts.
12-13-2022 08:45
12-13-2022 08:45
@AJISHERE Have you tried trouble shooting? Usually if sleep isn't being recorded then your HR monitor isn't on or working. You could try a factory reset, check the settings, and delete the sleep tile in the app and then add it back to see if that fixes it.
