My Versa 4 has been working great until last Friday evening. I had it off, and when I went to put it on, I noticed it was at the Fitbit logo. It has yet to change to anything else. I followed all the instructions listed here in the community, and where I get stuck myself is when it says to enter the code. I can't get any code as it's still stuck on the logo. Can anyone help?
Welcome to the forums @Tfellows.
Thank you for sharing the inquiry regarding this difficulty with Versa 4 and thank you for trying to fix it on your own.
Please confirm that you've tried the steps below in the order listed:
Unpair your Fitbit device from your phone's Bluetooth and Fitbit app.
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best AnswerHi, I've followed all of the steps you've written. I have nothing paired and as I go to pair my Fitbit, I have finally gotten it to show up as a device but when I select it to be paired I receive a message on my phone that states "An app is needed to pair this device". I never can get a 4 digit code on my Fitbit either.
I've now tried again, this time holding down the side button on the Fitbit, it flashes a few times then I receive a big red X, then it returns to the Fitbit logo app. When I was in the app and while holding down the button, the app was showing it as searching for the Fitbit, then after a while it would say, "Rry again."
I'm not sure what else to do.
Best AnswerHello again, do you have any other suggestions for me to try? Do I just need to throw it away and buy something else?
Thank you, TFellows
Best AnswerHello ManuFitbit:
My Fitbit is still not working, I've done everything you've told me to do. I even had tried that before I sent the initial message. Please help!
Hi Tfellows,
I, too have recently had this trouble.. I decided to restarted the mobile..
Restart the process of adding the Device back into the Fitbit app again.
Hope this helps.
Best AnswerDid this work for you?
Because I have the same problem, the red X and after a while also not possible to see the code to couple the device.
Already tried with switching off my Phone. I have gone to the shop where I bought it and they are going to check it.
Best AnswerWim85,
Did you also by any chance have set the watch to factory settings prior. That's what I also did. And it seems to work. Back to normal.
08:19
09:50
ManuFitbit
08-19-2024
08:19
09:50
ManuFitbit
I am having the same issues. Please let me know what you discover. I have tried EVERYTHING suggested. All I have is a blue fitbit logo. This all started after I installed the update on Saturday.
Yes. I have done this. All I have is a blue fitbit logo. The phone seems to see the fitbit asit keeps trying to pair, but the fitbit will not offer the four digit code or anything else.
Best AnswerI finally went through the Customer Service telephone line. Since mine is still.under warranty and they couldn't fix with "factory resets", they are going to replace under warranty. Not entirely satisfactory, as I had the same thing with my Sense 2, but a solution.
Best AnswerUnfortunately the shop where I bought it, could also not fix it. They gave me a complete refund and I can choose a new device that I like
