09-05-2024
00:27
07:57
EstuardoFitbit
09-05-2024
00:27
07:57
EstuardoFitbit
Versa 4 not charging ...just flashes logo
Best Answer09-05-2024 08:45
09-05-2024 08:45
Hi there, @RobG1246. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 4 is not charging. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. As per the description of your post, it could be a sign the contacts need cleaning. Confirm that you've tried all tips and recommendations provided here Why isn't my Fitbit device's battery charging?
Please make sure your Versa 4 is receiving good power source, please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
If after trying the above your Versa 4 is stuck on the Fitbit logo, please try the steps provided in this post while your Fitbit device is stuck on the Fitbit logo.
09-05-2024 08:45
