06-07-2023
10:16
04:53
06-07-2023
10:16
04:53
Hello everyone,
I have a problem with my fitbit. After the fitbit battery was empty en fall out. (to late to recharge)
I recharge my fitbit at home all night, but unfortualy i only see the fitbit logo on the screen.
I already push the button for 10 seconds, until the logo apears. From there the logo/screen switch a couple of times from green&black to black & green. After that I see a big red cross and two seconds later I see the normal logo again but he wont restart. I just see the Logo.
somebody know the issue?
Thanks you in advance!
Best Answer06-07-2023 11:56
06-08-2023 04:55
06-08-2023 04:55
Hi there, @Marrc0. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 4 before reaching out.
In addition to the steps you've done so far, please follow the steps below:
If you can't get started with your Versa 4, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If the above doesn't work, please follow @Guy_'s advice and chat with us online or give us a call. Click here to get connected.
21:32
04:29
06-08-2023
21:32
04:29
@Guy_ Thank you! I try to contact with the help support!🙏
Update: @MarreFitbit Thank you!
i try your steps, on some point my phone recognize my fitbit. But the step that there should be 4 numbers on my fitbit, stay out. Only the logo is visible on the screen.
But thank you for your help. I try to make contact with help support!
