01-14-2025
18:16
08:45
01-14-2025
18:16
08:45
I've had my Versa for 2 years. Never had an issue with it until about a month or two ago. Now, the battery only last 2 days if that. It was at 58% last night, woke up this morning and it was dead. I don't have extras running in the background. Now, it won't turn on, or sync. It flashes the Fitbit sign and then the red X appears. Is my Versa 4 a goner?
Best Answer01-15-2025 06:30 - edited 01-15-2025 06:30
Hi there @amb86_09! A warm welcome to the Fitbit Community!
Thank you so much for letting us know that your Versa 4 is only showing a red X and for all your efforts.
I suggest you try to do the following:
01-15-2025 07:18
01-15-2025 07:18
It doesn't even sync to my app. I have tried several times. I tried your steps to do a factory reset and that doesn't work either. At this point, I'm about ready to throw it out.
Best Answer01-15-2025 07:32
01-15-2025 07:32
Hi @amb86_09! Thank you so much for your answer and for all your efforts.
I'm sorry to hear that your Versa 4 is still not working.
Since you have tried the steps, please contact support if you haven't already. Fill out the form. You will then be recommended some help articles. After that, you will be able to choose how to contact support.
01-15-2025 07:57
01-15-2025 07:57
I've had it for 2 years. It's not worth trying to fix it now.
Best Answer01-17-2025 13:48
01-17-2025 13:48
I am going through the exact same issue
Best Answer01-20-2025 00:11
01-20-2025 00:11
The same thing is happening to me just started running out of battery very quickly. Couldn’t open screen and now the Red Cross. Only about 18 months , is it set in to make us buy new ones. Not very long lasting I have tried all the resets that they suggested worked for a day , now not working. Second Fitbit the first only lasted a couple of years. Not impressed.
Best Answer01-20-2025 05:19
01-20-2025 05:19
