07-18-2023
04:59
08:24
07-18-2023
04:59
08:24
Have red :cross_mark:
have tried numerous times and still can’t get the display to show anything.
it show all data on phone app and will sync.
is there anything else I can try, Versa is only 6 months old.
07-18-2023 08:26
07-18-2023 08:26
Hello there, @1954GP. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
If you haven't done so yet, I recommend following the steps below:
- Remove the Versa 4 from your phone's Bluetooth settings and in the Fitbit app.
- Restart your Versa 4.
- Turn off other Bluetooth connections when not in use.
- Plug it into the charging cable and open the Fitbit app.
- Set up your Versa 4.
If the issue persists, see Why can't I set up my Fitbit device?
07-18-2023 17:48
07-18-2023 17:48
Tried this, tried to setup fitbit will not pickup Bluetooth phone keep’s searching.
still black screen.
what else can be done.
Best Answer07-18-2023 19:34
07-18-2023 19:34
Now get to stage enter 4 digit code, but with a blank screen it’s impossible
07-21-2023 18:16
07-21-2023 18:16
All good contact help and support, a change over Versa 4 is being sent.
Versa 4 seems to broken
Best Answer07-23-2023 02:27
07-23-2023 02:27
Would be interested to see some additional feedback. I too have followed the instructions provided and it doesn't seem to be working. Nor does the link to Why can't I set up my FitBit device? help.
Don't understand why this two month old device is working fine, then all of a sudden I get nothing. Then following the various forum posts I get to the situation similar to the title of this thread: unresponsive, black screen; holding the button gets the alternating flashing logo followed by the red X; my phone sees the device and wants to pair, it's the device that won't respond.
07-23-2023 04:20
07-23-2023 04:20
Hi I contacted Fitbit help and support, after discussing my issues following reboot’s numerous times, Fitbit are now replacing the Fitbit, which I have posted off to them on Saturday.
will now await a new unit to be delivered should be approx 10 days.
very happy with support and help desk.
