04-05-2023
12:42
10:33
04-05-2023
12:42
10:33
I’ve had this Fitbit for just over a month and so far not really impressed.. it won’t download on to my phone, the battery life is hours rather than days and the day/date will not correct
anyone else having similar problems please .. thanks
Hi @Barkersmum - it sounds like a faulty watch, if you aren't using the GPS and can be replaced under warranty.
But a couple of things to try because it can be a firmware or just a syncing issue.
Make sure you have the latest firmware.
Turn off all other nearby Bluetooth devices, phones tablets etc.
Restart the watch.
Remove your watch from the phone's Bluetooth.
Logout of the Fitbit App, swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Login again and wait for any pair, link or Fixit prompts .
Pull down on the watch face to do a manual sync, if that doesn't show progress on green status bar at the top after a few minutes, click on profile photo and "+ Set up a Device" and replace.
Hi there, @Barkersmum. Welcome to the Community Forums. Thanks for the details provided in your post about the issues with your Versa 4.
In addition to the steps that @Guy_ has recommended, please follow the steps below:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
As for the battery drain, please see Can I extend my Fitbit device's battery life?
