Versa 4 vibration strength
I upgraded to the versa 3 and the vibration is hardly noticeable compared to other watches.  Is the Versa 4 stronger/upgraded?
7 REPLIES 7
Hi there, @Bnetty. Welcome to the Community Forums.
Please note you can adjust the vibration strength either on the Versa 3 or Versa 4. For more information, see How do I navigate my Fitbit device?
See you around.
Hello, I have the setting maxed and it is weaker than other Fitbit’s I’ve bought.  I’m looking to upgrade to the versa 4. Does it have a stronger vibration mode than the 3 or is it the same?
Had a Versa 2 and this Versa 4 seems weaker, vibrationwise. Setting is maxed
Hi @Bnetty - the Versa 2 is the last of the smart watches with good vibration strength, anything more recent isn't a match, as @teesquar says.
Hi had the original Versa and loved the strength of the notifications. I just received the Versa 4 and I can barely feel any alarms or notifications. I've been searching on how to make it stronger, however, I still haven't figured it out.
Hi @Tfellows - you can't make it stronger, even the setting on strong makes very little difference and it gets marginally weaker as the battery level falls, so the best is when it's fully charged and even then it's not a match for a Versa/Versa 2.
Be aware that Fitbit have a 45 day refund policy or possibly authorised dealers too, some stores provide 14 to 30 day refunds.
