Versa 4 won't charge
ANSWERED
My versa 4 won t charge, doesn’t work
1 BEST ANSWER
Accepted Solutions
Hi there, @Thomaskrul. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your new Versa 4 is not charging. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Versa 4 on the wall socket, try using another CE certified USB adapter for low energy devices.
If you haven't done so yet, I'd recommend following the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
1 REPLY 1
