04-21-2025
14:09
09:21
04-21-2025
14:09
09:21
My wife's fitbit is stuck on this screen.
I have tried multiple times to do the reset using the button on the side, it'll vibrate and disappear but then it just goes back to this screen.
No idea what to try next as all the options involve navigating the watch itself when I can't access it.
Thank you.
04-21-2025 18:27 - edited 04-21-2025 18:29
Hey there @JoshBerrington, welcome to the Fitbit Community.
Thanks a lot for taking the time to share the steps you've already tried. Let's work on getting this resolved!
I see that you tried to share a picture with us, but unfortunately, it didn't go through. Could you please try sharing it again? In any case, could you describe what type of screen you're seeing? Is it the Fitbit logo, or is it stuck on the clock face? Please let me know!
Meanwhile, changing the clock face through the Fitbit app can refresh the display.
04-21-2025 20:27
04-21-2025 20:27
My Fitbit is having a similar problem. It only lights up when connected to the charger. The icon is the Fitbit logo. It also buzzes when plugged in but that’s all. The button won’t reset it whether it’s connected or not. I’ve taken it off the charger after a day and the screen still doesn’t light up at all. I’ve only had it since December 2022. To try to fix it, I disconnected it from my phone since that’s worked before. The battery was not struggling before and this only started once it died this past weekend.
04-21-2025 20:32
04-21-2025 20:34
04-21-2025 20:34
Hi Estuardo, I have hopefully uploaded the photo this time. This is the screen it is stuck on.
Thank you.
04-22-2025 20:43
04-22-2025 20:43
Hey there @JoshBerrington indeed, the picture is there! @Cherry2, Welcome to the Community.
Thanks for all the steps you've tried so far. Based on your picture, here's some advice before we continue.
First, let's try setting up your device as new. Here's how:
You don't need to remove your device before doing this. Also, have your WiFi password ready, as you may need it again.
Best Answer04-22-2025 21:10
04-22-2025 21:10
My app has no updates and the watch won’t connect to anything (including Bluetooth) It just sits on the Fitbit logo and unable to reset using multiple forums and having experience with a versa specifically for over 5 years.
Best Answer04-23-2025 17:09 - edited 04-23-2025 17:09
Thanks @Cherry2, for letting me know that, let's try from a different point of view!
We have a way to factory reset your device without using the settings, this is a little tricky but let's try together.
Once you have done that, try to set up the device one last time!
