06-28-2023
11:08
03:59
06-28-2023
11:08
03:59
Hi... Can anyone helo please. I have purchased a fit bit versa 4 and set it up today. I have noticed when I get a whatapp call is says"unkown caller". I have all permissions turned on.
My phone is a samsung 21 ultra.
Can anybody help with this issue. Thank you
Best Answer06-29-2023 04:03
06-29-2023 04:03
Hi there, @Houli24. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Versa 4 before reaching out.
Since you've already checked all the notifications settings are correct, I'd like you to please confirm if you have enabled the Fitbit app permissions under Settings of your Android device. If you've done that, please try going to the phone Settings > Apps > Fitbit > Permissions and toggle off "Contacts", then restart your phone and toggle "Contacts" back on.
Also, check that your Fitbit app is up-to-date. For more information, see What's changed in the latest release of the Fitbit app? To download the latest app version, please visit the Google Play Store here.
If none of the above works, please follow @Guy_'s advice and chat with us online or give us a call. Click here to get connected.
Best Answer06-29-2023 01:19
06-29-2023 01:19
Hi @Houli24 - have you tried in the Fitbit app > Notification > Calls (Toggle OFF and ON) and sync.
Also try
Best Answer06-29-2023 03:08
06-29-2023 03:08
Best Answer06-29-2023 03:15
06-29-2023 04:03
06-29-2023 04:03
