08-29-2023
16:46
03:48
08-29-2023
16:46
03:48
My Versa 4 won't sync with my phone fitbit app. It also has the wrong time by 24 minutes. I force stopped and restarted, still won't sync. My versa 4 shows activity but not on the app.
Best Answer08-30-2023 03:52
08-30-2023 03:52
Hi there, @Paleth. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
In addition to the steps provided by @Guy_, I'd also suggest trying the following:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Once you manage to sync your Versa 4, the time should be corrected. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
08-29-2023 21:47
08-29-2023 21:47
Hi @Paleth - this may be phone related, try Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Make sure there are no other devices running the Fitbit App switched on.
Restart the watch by holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Login and wait for any pair, link or Fixit prompts and sync.
Once the phone is syncing it should set the time.
08-30-2023 03:52
09-04-2023 08:11
09-04-2023 08:11
Thanks. It worked. I was about ready to return this Fitbit because I only purchased in April 2023 and have had several issues with it. Hope it continues to work as it should. Thanks for your help.
