11-03-2024
14:14
07:28
11-03-2024
14:14
07:28
Not sure if this has to do with the updat or HAVING to log in via Google versus fitbit but nothing works correctly anymore. I do not like not having the option anymore of logging in via fit bit. I don't like the idea of Google knowing all my information. Anyway I can not sync my versa with my phone. I have done ALL of the troubleshooting steps more times than I care to mention and nothing is working. I try to pair and my phone tells me that an app is needed. This is ridiculous.
Hi there, @Kgrubb68. It's nice to see you around the Fitbit Community Forums. Thank you so much for following the suggested troubleshooting steps. I am very sorry for all the inconveniences this situation has caused.
To better assist you, may I know if you're using an Android phone? Please note that a Fitbit (Android) App Bug that caused issues with Syncing and Pairing has been Fixed. If you're still experiencing pairing issues, I'd recommend upgrading to the FitBit App version 4.28.2 since it includes a Bug Fix. For more information, see How do I update the Fitbit app?
However, if you update to 4.28.2 and still encounter a pairing bug, I suggest you to restart your phone.
If restarting your phone still doesn't resolve the pairing bug, listed below are the recommended troubleshooting steps to solve these problems:
Best AnswerHello. Thank you for reaching out. have tried all of your suggestions more times than I wanted to and I am still not able to sync my phone to my watch. I have a Samsung Galaxy S23+ and I have most updated version of fitbit. I am not able to get rid of my "app is needed " under my blue tooth. This is exhausting.
