10-10-2022
11:31
11:50
10-10-2022
11:31
11:50
I have the new versa4…like many others I’m disappointed in the lack of features currently. One big item I can’t get to work is the versa4 to recognize I’m asleep. I was able to manually track sleep but it won’t recognize I’m asleep, isn’t tracking my heart rate, skin temp or oxygen level. This was the main features I wanted. Any tips on getting this to work? I’ve done everything from reinstalling, etc.
Best AnswerI have no issues with mine detecting sleep, so not a systemic issue. Here are a few questions…
It could just be a problem with your watch, but taking a few more troubleshooting steps may help pinpoint the issue. You can also consider doing a factory reset on your watch, then reinstalling it from scratch, but before doing something that draconian try the simple things first. If it still doesn’t work after that Fitbit support is the best option.
Hi there, @Lewarctj. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 4 before reaching out. I understand where your concern is coming from and how you must be feeling. @SunsetRunner Thank you so much for helping out!
Please note there are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
For more information, see What should I know about Fitbit sleep stages?
