I noticed yesterday that my miles are no longer calculating on my verse 4, and they used to. I’ve restarted it multiple times, shut it down, took blue tooth off.. everything I can think of. I need to get 10 miles in every day and not knowing my miles is killing me. Any ideas on how to fix? Everything else is working..
Best Answer@Sreseburg This is a known bug. The fix is to set a manual stride length in the app.
If you're on iOS, you might have to scroll down far enough to see the Stride Length option. Android settings might look a little different.
