09-06-2019 09:31
09-06-2019 09:31
I would like advice on the best high-definition transparent film protector for my Fitbit Versa Lite. The Fitbit advocate I called said Fitbit did not manufacture a film face protector like Otto does for Smartphone screen protection, but suggested that I contact the Community for advice. He said Amazon offers several and I did see one by Supershieldz but I'd like your advice before ordering.
09-06-2019 17:38 - edited 09-06-2019 17:45
Hi, in principle your Versa does not need a screen protector because of the Gorilla glass, but I you want to use one for certainty, the Supershieldz is a very good one. A few of my friends have it and are very satisfied with it. Personally, I do not use one, regards kuzibri
09-06-2019 18:42
09-06-2019 18:42
Hi @SydH I always use a screwn protector on my fitbits. My personal choice is iq Shields. They are wet install so much easier to position than the dry install ones (you can move them on the screen) and they last a long time before needing to be replaced.
Helen | Western Australia
09-06-2019 19:13
09-06-2019 19:13
I use a screen protector on my Versa & am glad I do. I got mine on Amazon. Just search for Fitbit Versa screen protectors. You can get packs of 3 or 4 for about $12 or less. I banged my watch against the dryer door one day & shattered the protector. No damage to the watch.
09-07-2019 03:52
09-07-2019 03:52
09-07-2019 03:54
09-07-2019 03:54
Thank you, Nelly. Very helpful. I appreciate your help and quick response.
Syd
07-14-2020 11:13
07-14-2020 11:13
What brand did you purchase for your fitbit?
