05-15-2018
13:34
09:23
AlejandraFitbit
05-15-2018
13:34
09:23
AlejandraFitbit
I have the Fitbit versa and I'm very disappointed. It was working when I first bought I received all my notifications and not since it did an update on Saturday it's not working. I get told Today that it's not compatible with my phone. Why sell a product and it not work with all phones. When is this going to work? Is it ever going to work?
05-15-2018 13:44
05-15-2018 13:44
Hmm I also have the LG V30 and I have no issues with notifications on the latest software. I don't know if it makes a difference but I have the "always connected" and "keep alive widget" settings enabled.
I agree it's annoying that "device not compatible" seems to be Fitbit's default excuse when issues come up since most of their officially-supported devices are outdated models. It's like they expect their customers to be using the newest smartwatch on 4-year-old phones.
05-15-2018 15:18
05-15-2018 15:18
05-15-2018 20:28
05-15-2018 20:28
Yes, I got the update to 32.32.10.15 last week. My Versa is working the same before and after the update. Sorry to hear it didn't work for you 😞
05-20-2018 14:04
05-20-2018 14:04
If i buy versa can i use it with my v30,
05-25-2018 12:02
05-25-2018 12:02
No it will not work. I do not get my text calls nothing on my versa
05-25-2018 12:05
05-25-2018 12:05
What about other features , health related
05-25-2018 12:12
05-25-2018 12:12
I gave up on trying to get any other notifications so i'm not sure.
07-03-2018 09:00
07-03-2018 09:00
My V30 (Oreo 8.0) and Versa (32.32.10.15) is updated to the latest firmwares. The watch no longer syncs as well...
07-06-2018 09:23
07-06-2018 09:23
Hello everyone!
I hope you are doing fine. Regarding your inquiry about the phone's compatibility, Fitbit is compatible with more than 200 of the most popular Android, iOS and Windows mobile devices.
The full list of compatible devices with confirmed compatibility can be found here. If a device isn’t listed it doesn’t mean it won’t work with a Fitbit tracker or smartwatch. We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit App, and are constantly working to confirm compatibility with new phone models.
A majority of Android phones running version 4.4 or higher will work with our products, however we cannot guarantee optimal performance on devices for which we have not tested and confirmed compatibility.
Catch you later.
08-04-2018 05:21
08-04-2018 05:21
Hello i have also a Lg V30, had before Sony xperia Z5 , never a problem with sync there, but with my new Lg V30 the problems began, syncing problem all the time. Annoing it is. Dont know what to do, otherwise im am satisfied with its functions and so on.
08-04-2018 08:52
08-04-2018 08:52
@avocadotoast wrote:Hmm I also have the LG V30 and I have no issues with notifications on the latest software. I don't know if it makes a difference but I have the "always connected" and "keep alive widget" settings enabled.
Just an update from me - I ended up getting a second LG V30 because I broke my first one. I transferred all my app data, so the Versa was already set up on my new phone without me having to go through the connection steps. I think this caused some issues because it wasn't syncing properly and I wasn't getting notifications. I decided to remove the Versa from my account and go through a brand new setup. During setup, I had trouble getting the phone to find the Versa, but fixed this by manually removing all other Bluetooth devices that were connected to my phone (I re-added them after Versa finished setting up).
Now I have no issues syncing and getting notifications on my new V30 (running Oreo 8.0.0). Once in awhile, I have to sync it manually but not a huge annoyance. It might be because I also have an Alta HR on my account so sometimes the app takes time to sync both.
I don't doubt that other V30 users have legitimate issues syncing and I'm wondering what the difference between my V30s and other users are. Could be Bluetooth settings, regional differences in hardware, etc.
08-05-2018 01:30
08-05-2018 01:30
Hello , ive got it to work now. I did a reset to factory on the Versa and removed the pair in bluetooth at the LG V30. Reinstalled the fitbit app at the phone, after a bit of struggle and time got it to be installed correctly again followed the instruction by the book. Its now so far working again. So dont give up you folks, try what i did. And the money you spend on Versa is not waisted. I'm happy again
08-06-2018 06:22
08-06-2018 06:22
Its working on my V30....no problem so far
12-04-2018 08:39
12-04-2018 08:39
I have a Fitbit versa and an LG V30. I upgraded my phone from the LG V20 and upgraded my Fitbit from the Fitbit charge 2 to the Versa. I had no issues with the old phone and Fitbit, the both synced and I received all notifications including call notifications.
Now after my upgrade I receive the majority of notifications but no telephone call notifications. Also at time there are issues as the phone does not seen to recognize my Versa. I love both my phone and Versa just a sham they are not totally compatible.
Its sad as I thought that the way to go was to upgrade.
12-21-2018 08:36
12-21-2018 08:36
I recently got an LGV30, and I'm not even able to pair my Fitbit Blaze with the device! Phone literally can't detect the tracker.
12-25-2018 19:26
12-25-2018 19:26
Same, can not even get it to sync to mine at all! Dissapointed
03-15-2019 11:20
03-15-2019 11:20
I suggest you get the LGV40 tested because a lot of people going to LG because they are great phones.
