09-04-2018
04:19
12:35
HeydyF
09-04-2018
04:19
12:35
HeydyF
Has anyone found an Oppo phone that syncs completely with the Fitbit versa?
I'm looking at the Oppo Find X or the R15 Pro.
Thanks.
09-04-2018 05:05
09-04-2018 05:05
If it is not on the approved FitBit list . . . .
09-05-2018
12:44
13:19
09-05-2018
12:44
13:19
Hey @Leroyhuey, welcome aboard! The Oppo phone models that are officially compatible with Fitbit trackers, are those that appear here. Other ones, as those that you mentioned, might work with the Versa but I can't guarantee that. You can follow the troubleshooting in this help article: Why can't I setup my Fitbit device? and if you were able to pair them but having syncing issues, you can review the troubleshooting in this other help article: Why won't my Fitbit device sync?
Thanks for stopping by @GreginJaxFL.
Keep me posted!
09-05-2018 14:59
09-05-2018 14:59
They do work but not well.
09-05-2018 21:34
09-05-2018 21:34
Thanks for your reply.
All the phones on the list don't seem to be available in Australia. Is there a reason for this?
thanks.
09-06-2018 01:51
09-06-2018 01:51
Some Oppo Mobile Are compatibility With Versa Like Oppo A57, A75
09-07-2018 05:04
09-07-2018 05:04
Hey @Eriklb, I hope you are doin' fine! Yes, that is something that happens also when you are using a non compatible device with Fitbit trackers. They don't work completely or not all the functions will work as expected, as if you were using a compatible phone or tablet. So I normally suggest to troubleshoot it by checking this help article, but just keep in mind that I can't guarantee that those steps will fix the issue.
@Leroyhuey, to be completely honest with you, we as moderators don't know exactly in which countries some phone models work and others don't. We can just provide you with general information about the compatibility of certain phone models.
@davidjones, there are a few Oppo phone models that are compatible, and I guess that there are some others that work with Fitbit devices, even though they don't appear on the list. Maybe they are under testing, and your Versa might work with some of them but I can't guarantee that inconveniences won't appear.
In this case guys, I will ask yo to be patience, as our team is always working in order to add more compatible devices to the list.
11-26-2018 14:09
11-26-2018 14:09
I have the oppo a71 and would love for it to be compatable.
11-27-2018 09:02
11-27-2018 09:02
Hey @Livesniper123, let me give you a warm welcome to the Community! Our team is always working in order to expand the compatible devices list, so this phone might be available as compatible anytime, I can't tell you when, so I will ask you to be patient. However, you can try to setup/sync your Versa with it. I can't guarantee that it'll work but you can give it a try. In the meantime, you can also try to setup/sync your Versa with a computer that meets the requirements. You can take a look at the information in this help article: How do I set up my Fitbit device? For further questions!
Let me know if you have further questions!
04-05-2019 16:54
04-05-2019 16:54
@HeydyF Considering that this post is now around 8 months old, and that there seems to be a great demand for supporting Oppo devices which are available in Australia, can this be escalated as an issue for your company and be resolved as soon as possible? I was told by customer support his morning that the software engineers monitor this forum to identify issues and establish the need for further software/hardware development. I think that this qualifies as a need.
04-06-2019 10:18
04-06-2019 10:18
Yes agree wholeheartedly. I have an R15 and while it seems to work ok have a lot of problems syncing.
06-12-2019 04:46
06-12-2019 04:46
Quando sarà compatibile con Oppo Reno ?
06-12-2019 16:21
06-12-2019 16:21
I have the Oppo R15 Pro and just bought the Versa and the bloody thing won't show up on my device list on app but it says it's connected ...
06-13-2019 09:03
06-13-2019 09:03
I just bought a Versa but it wouldn't set up on my Oppo F11 Pro, which is barely a month old. I'm really, really disappointed.
06-13-2019 14:02
06-13-2019 14:02
Yep. It's disappointing. Lucky for me I have a Samsung to I use so hooked the Versa up to that till they make the oppos compatible.
06-17-2019 15:25
06-17-2019 15:25
My Oppo r15 pro won't connect to my fit bit versa who can help
06-17-2019 15:28
06-17-2019 15:28
How do U get it to work mine hooked up but won't turn my notification on
06-19-2019 20:16
06-19-2019 20:16
I have Oppo Real me 1. It was working and syncing well for almost 6 months, don't know from past 2-3 months GPS not syncing also, track excercice in the mobile stopped working..
All the malfunction happened when my first tracker replaced with the new one.. Really it sucks.
06-19-2019 21:59
06-19-2019 21:59
I bought a Fitbit Versa today and I can't even set it up. I get to the point where the Bluetooth on my phone finds the device during the setup process, then the setup part crashes and the app goes back to my Fitbit profile and I have no device connected. I rang Fitbit and went through all the troubleshooting processes and was even told my phone IS compatible (Oppo R17 pro).
They told me to take the Fitbit back for a refund...
Do I do that or should I wait until Fitbit sort out this Oppo issue??
06-19-2019 23:30
06-19-2019 23:30
UPDATE - I tried setting up on the computer, this time it got past the Bluetooth stage but couldn't connect to wifi
