Pairing airpods
I cant pair my airpids
44 REPLIES 44
So you've gone into the settings on the Versa->Bluetooth connection->New device ? If you've done all that, try a restart.
“Just keep swimming,Just keep swimming, swimming, swimming”- Dory
If you find my answers helpful, Vote for them and accept them as the Solution!
Ionic | Charge 2 | iPad 2017 running iOS 12.1.2 Beta
I have airpods and im not able to setup mine with my fitbit versa. How did you fet yours setup.
Same for me. My versa doesn’t find my EarPods. They are visible on my iPhone and i can connect them to it but they are not visible on my versa watch
How can this be fixed ?
Have a great day!
I'd recommend a factory reset( but try a restart first ) if your Versa/Ionic isn't pairing to the Airpods.
I was i able to connect my AirPods to my fitbit versa. I had to remove my AirPods from my iPhone X Bluetooth and i walked into another room. Then went to settings and Bluetooth and touch add audio device and held my AirPods close to my fitbit. My AirPods showed a white light and paired up my AirPods and fitbit versa together.
Sent from my iPad
Yes, BT interference often messes up the pairing process of pairing the watch to the phone and the watch to another BT device.
I works for me. I went in to my fitbit device and touch my AirPods and it was setup.
Sent from my iPad
It worked for me when I held down the button on the back of my Airpods until they were recognized on my Versa.  Then they paired perfectly
I was able to do mine.  Here's what I did.
1.  Removed them from my iPhone
2.  Took my Airpods (in their container) to another room.
3.  While in the Bluetooth mode on my Versa I pushed in and held down the button on the back of my Airpods container.
4.  It then recognized them on the watch and connected.
@Tylstin did it connect first time for you? I am having the same problem, have tried all your steps above but the Versa recognises the Airpods but will not connect. I was wondering if this was the same with you but after a few attempts connected. This is extremely frustrating.
It found them right away. Once I selected them on my Versa it completed the
pairing. But I have noticed that every time I turn on my music I have to
select to use my AirPods.
Yes it connected for me. I had to turn off my Bluetooth on my phone and then I went into another room away from my phone and held my AirPods open to my versa went to my settings to Bluetooth settings and started pair my AirPods to my versa it will show white color as it pairing then touch my AirPods on the versa and it will pair. Once it done the when you ready to listen to your music go to you Bluetooth and your versa and touch your AirPods and it will start working. Hope this helps.
Sent from my iPhone
Thanks I did tried your step my Versa found my Airpods but not connect. Maybe I will return my  Vwersa to store.
Sent from my iPhone
Thanks my Versa found airpods but not connect. Reset factory not help.
Mine paired fine and will play what I am attempting to play on my Fitbit but once completely out of range from my phone I get static or in and out connection.
my Versa found my Airpods but can't connect
Wonderful and yes I have click on the my AirPods also to listen to my music.
Sent from my iPhone
Thank you for the detailed instructions.  Worked perfectly after fiddling with it for 1/2 hour!
