04-22-2018 10:59 - last edited on 07-27-2021 12:10 by JuanJoFitbit
I have the SE version and added two cards through the application which I can view on my phone. When I first added the cards I could see them on the wallet app on the versa and pull the app up with a long press of the left button. Now, the long press only pulls up music controls and settings but not the wallet and the app on the device just tells me to press the left button (which doesn't work as stated). I tried uninstalling the app on the device, restarting the device, reinstalling, and then restarting again, but I still have the issue. Thoughts? Anyone else experiencing this or have a way to fix it?
04-24-2018 07:43
04-24-2018 07:43
Hello there @Marshjenni, nice to see you around in the Fitbit Community! I was reading you are not able to see the Wallet tab on your Versa. Thank you for letting me know the steps you ahve tried to address this issue.
By any chance you tap the Hide button?
When this option is tapped, the Payment tab disappears. To see it again, set up another card in the Wallet. What should I know about Fitbit Pay?.
Hope this helps and let me know how it goes.
04-24-2018 07:43
04-24-2018 07:43
04-24-2018 08:02
04-24-2018 08:02
Thanks! I didn't have another compatible card, but either the attempt to add or changing the default did the trick.
04-30-2018 07:49
04-30-2018 07:49
I also have a problem with wallet on Verso. Two cards set up and working correctly, payments made. Went to make a further payment and it reported 'set up wallet' no cards have been added in your wallet. From my mobile I changed the default card. Both cards then appeared correctly. A bit later, I checked again and the cards had disappeared. Hopefully this can be fixed quickly as I make a lot of contactless payments.
05-02-2018 06:00
05-02-2018 06:00
Hi!
I have the same issue with the Wallet not appearing when pressing and holding left button. Only notification settings and music control options are available.
I have tried the following to no avail:
- Disabling and re-enabling card
- Removing and adding card
- Adding a 2. card (as suggested here)
- Uninstalling and reinstalling wallet app
- Rebooting watch several times and after each new attempted remedy
No chance getting the Fitbit Pay / Wallet to work, either by pressing and holding left button or launcing the app on the Ionic. The latter only tells me to press and hold the left button.
The only thing I have not done is to contact my bank to verify the cards again. I already verified them once and would like to avoid calling them again unless I know this issue is solved.
05-02-2018 06:13
05-02-2018 06:13
05-09-2018 03:04
05-09-2018 03:04
@RobertoME wrote:Hello there @Marshjenni, nice to see you around in the Fitbit Community! I was reading you are not able to see the Wallet tab on your Versa. Thank you for letting me know the steps you ahve tried to address this issue.
Still not working for me. Quite annoying I must admit.
05-10-2018 01:35
05-10-2018 01:35
05-15-2018 05:36
05-15-2018 05:36
I have the same issue with the Wallet not appearing when pressing and holding left button. Only notification settings and music control options are available.I have tried the following to no avail:
UPDATE:
The latest Software update (27.32.10.15) did not solve the issue, however a full factory reset did.
Fitbit team, please look into this on your next software release.
Thanks.
05-23-2018 05:36
05-23-2018 05:36
Hi @ErikBM and thank you for your help on this issue @jwchigh. My apologies for the late response and thanks for calling this out. I'm glad to hear with a factory reset you were able to bring back the wallet option on your Versa.
I will pass forward your comments to our teams to keep an eye on this behavior.
See you around and stay tuned of you have other questions.
06-07-2018 19:47
06-07-2018 19:47
Not seeing the wallet option on my mobile app. It’s on my versa but not in the mobile app. What can be done?
09-08-2018 12:48 - edited 09-08-2018 12:49
09-18-2018 04:25
09-18-2018 04:25
I also face the issue in the case of Samsung pay, not adding the cards properly. I go to the site and find the solution. If this helps you visit it.
http://technicalhelplineaustralia.com/samsung-pay-support.html
09-30-2018 08:47
09-30-2018 08:47
Hi there where is this hide button? I had the wallet working and it now doesn't so I' confused. iphone 6
03-18-2019 15:21 - edited 03-18-2019 15:22
If you go into the app and then to wallet. Go to your default card and suspend it (scroll all the way to the bottom) and then unsuspend card it unhides the payment option on your Versa.(When long pressing left button)
Hope that helps someone else.
And I think it has something to do with setting up fitbit windows app on Win 10 PC also. Since installing Fitbit on my pc I've had nothing but problems, removed it from the PC now.
12-20-2019 02:45
12-20-2019 02:45
I executed a hard reset on my versa (press 3 buttond at the same time, hold it until the Fitbit logo appears) and that solved the problem. My card is woring now. Accoring to the fitbit team, I had to call my bank, but that is rubbish. It definetly is a fitbit problem. But this solves it. Hopefully Fitbit 'll release a new update that definetely resolves this problem
07-26-2021 19:22
07-26-2021 19:22
Same issue for me. Card shows up on my phone app, but then only available sporadically on the Versa. When I go back to the app and view the wallet it seems to work on the watch for a little while, but then clears out.
02-07-2023 04:43
02-07-2023 04:43
I have 2 cards - CC and Gift card. I have removed the gift card, but still could not sync with the wallet. The same continues spinning Syncing with the wallet...
