05-02-2018 14:13
05-02-2018 14:13
I have only just noticed this but my versa is showing April & not May. Anyone know how i can change this ?
05-02-2018 14:41
05-02-2018 14:41
It should get date and time from phone (or other sync device) every time it syncs.
Best Answer05-02-2018 14:49
05-02-2018 14:49
Actually, it seems that this is happening with certain Clock Faces. Probably an error from the Clock Developer. Change your clock face and you should be fine.
05-02-2018 14:53
05-02-2018 14:53
Thank you, will change the clock face & see what happens as everything else has the correct date on it.
Best Answer05-02-2018 14:58
05-02-2018 14:58
@MichelleP I happened to have picked a face that just has "WED 02" for the date. Easy for them not to mess up the month, I guess.
Best Answer05-17-2018 14:09
05-17-2018 14:09
It is an error with the clock face as Kathy said however you don’t have to change it. Go into the clock face settings in your fitbit app and to current clock face, on mine with this issue it said “update” so I clicked that and then synced my Fitbit again and the problem was solved!
05-18-2018 09:57
05-18-2018 09:57
This was very helpful, thank you! I had the same issue with the wrong month showing. I went into the clock face settings and just needed to update it
