07-11-2018 07:16
07-11-2018 07:16
Whenever I select "bike" (real bike riding outside), the Versa shows "connecting" on the screen, but never changes. The Versa will show calorie activity, but never miles. My Android 7.0 phone recognizes "Versa" in Bluetooth and shows it as 'paired", but if I select it (Versa) from the Android Bluetooth menu, unlike all the other Bluetooth accessories which are paired and will say "connecting", the Versa does nothing. What am I doing wrong? Sorry for any confusion, but as my screen name implies, I'm new to the Fitbit world.
07-11-2018 07:28
07-11-2018 07:28
@newbiecathy Ok, I understand that you are using the Exercise shortcut Bike and trying to use the Connected GPS feature within Bike. First, did you touch the little gear icon in Bike on your Versa and enable the Connected GPS? Also, your location services need to be ON in your phone. My suggestion is that you close all other apps running on your phone but leave open the Fitbit app and, if you want, something to listen to. Do a sync so that you know the connection between your Versa and phone is fresh and connected. Start the Bike Exercise by touching the Bike screen and then try to wait for "connected" to show before you start your bike ride. At the top of the Versa screen it should show your accumulated milage. However, sometime it will say "connecting" as it tries to re-establish a connection between the Versa and phone.
All that said, Bike seems to be the worst about behaving for Connected GPS. Disconnects, poor milage calculations causing incorrectly calculated stats are the bulk of the problems. I've wondered if it has to do with the Refresh or Sampling rate between the Versa and the Phone and the speed with which you are traveling. Frequent disconnects and fast speed seem to result in lots of dropped distance. I have no issues using it for Walk or Run but many, many other here will report that it rarely works for them regardless of the Exercise shortcut chosen. Good Luck and let us know how you fare.
07-11-2018 08:24
07-11-2018 08:24
05-16-2019 12:35
05-16-2019 12:35
I have tried all of the suggested ways to get the Versa to use the Phone for GPS, none actually work. Even when the screen on the Versa stops showing "connecting", the Versa never gets GPS tracking / distance data from the phone. VERY AGGRAVATING!!
07-09-2019 10:10
07-09-2019 10:10
I have also spend countless hours trying to get the Fitbit Versa to track distance and speed while biking. I have even carried an extra smartphone with location on and registered. I even have two different mobile networks and both work great. Basically it comes down to this, it tracks steps and heart rate. Calories are not accurate. Speed, distance or anything GPS related is non existent. Seriously thinking about returning mine. Very disappointed.
08-15-2019 18:49
08-15-2019 18:49
I just started using a new Versa and I have the exact problem! No stats recorded except time and heart rate, no distance, speed or anything? My Runkeeper app has no problems connecting. What is the issue?
05-19-2020 10:50
05-19-2020 10:50
Had the similar problem.
The solution is to make sure that Fitbit app has access allowed all the time. This is setup from the setting location function.
