07-28-2025 06:40 - edited 07-28-2025 14:47
I’m using a personal application connected to my own Fitbit account, and for about a month I was able to access HRV intraday data through /hrv/date/{date}/all.json without any issues. However, this endpoint recently started returning a 403 PERMISSION_DENIED error, even though I continue granting all the required permissions during the consent flow. Other intraday data (such as heart rate, steps, or calories) still works correctly, only HRV access is failing.
Could you please help me understand why this is happening and how I can restore access to HRV data?
07-31-2025 13:51
07-31-2025 13:51
Hi @Josema003
This is a known issue. I have added your name to the bug ticket. I'll notify you once this issue is resolved.
Best Answer07-31-2025 13:51
07-31-2025 13:51
Hi @Josema003
Best Answer08-17-2025 09:34
08-17-2025 09:34
Please add my name to the bug ticket, same issue
Best Answer08-18-2025 06:59
08-18-2025 06:59
Will do. When the problem is resolved. I will update this post.
Best Answer12-18-2025 12:54
12-18-2025 12:54
has this been solved? having issue connecting the iOS app I'm developing while it works on web
15:52
12:01
GordonFitbit
12-18-2025
15:52
12:01
GordonFitbit
Hi @LucasCoelho
Our engineering team is addressing the issue, we do not have a public timeline for the fix at this time.
For workaround, we can manually enable access for your application. To request this, please submit a ticket via our official developer issue tracker: <bad link>
Once you have submitted the request, we will review and get the necessary access enabled for you.
Thank you for your understanding.
Best Answer12-19-2025 04:45
12-19-2025 04:45
I'm getting `Error 400 while fetching challenges: invalid parameters` when trying to connect to https://b.corp.google.com/issues/new?component=1677887&template=2088089
Best Answer12-19-2025 10:46 - edited 12-19-2025 10:47
Hi @LucasCoelho
Here is the Issue tracker link from our official documentation https://dev.fitbit.com/build/reference/web-api/intraday/
Can you please try again and let me know if it works for you? Thanks.
Best Answer12-19-2025 11:51
12-19-2025 11:51
Hi Doris, I'm still seeing 400 error when trying to login. Which credentials should I use? I'm using the gmail used to create this account I'm using here in this forum. Do I need to sign up anywhere?
Best Answer12-23-2025 14:13
12-23-2025 14:13
Apologies for sending the internal link. Please try this link instead: https://issuetracker.google.com/issues/new?component=1677887&template=2088089&pli=1
Please let me know if you have any issues accessing it.
