05-29-2017 06:55 - edited 05-31-2017 03:37
Hi Team,
I was trying to add body fat percentage from fitbit web application but unable to do so, the form where the body fat needs to be entered, as a "log" button which seems disabled. After entering the value, when I click on it, I can see that the page is submitted but then, neither I get an error nor it is reflected in the application that it is accepted.
Pls help me, a snapshot is taken to show where I had been entering this.
Later I tried to update the records from the backend using API but that also doesn't work for me.
The end point I used is - https://api.fitbit.com/1/user/<userid>/body/log/fat.json
And the message I am passing is -
"weightLog": {
"bmi": 23.57,
"date": "2017-05-05",
"fat": 14.5,
"time": "23:59:59",
"source": "API"
}The error I am getting is below -
"errors": [
"errorType": "validation",
"fieldName": "fat",
"message": "Fat is required"
}I tried to remove every element of JSON and use only fat, but that also didn't help me to get this error out.
Requesting help here. Thanks.
Regards,
Ritu.
