Hi, first time poster, sorry if I have the wrong forum, copied the altimeter example https://github.com/Fitbit/sdk-altimeter (except LICENCE and README.md) into fitbit studio, package.json is text based on the github example but graphical on fitbit studio, so chose type app, versa3, sdk v6, location permission, english locale. When I run I get
These files are not on the github altimeter example and I cant see them being called from any of the code, any suggestions, thanks tonyf1
Best AnswerThe problem is probably that the project was written for SDK4, whereas you're targeting SDK6.
The main changes came between SDK4 and SDK5; see how you get on with the Migration section here.
Best AnswerYes, that fixed it, thanks. Who would I contact to have the documentation at https://dev.fitbit.com/build/tutorials/examples/ improved? I think it is important because its one of the starting places for new programmers.
I suspect they know. Submitting an issue to the relevant git repo would probably bring it to the developer's notice; raising a pull request with SDK5/6 code would be even better!
Many Fitbit-related repositories are managed by non-Fitbit people.
Best AnswerHi all
For what its worth, I have decided to write some beginner level tutorials, my first http://drrea.org.au/Fitbitstuff/tutorialbart.pdf provides a little more help on running the Tutorial SDK example app "Bart" at https://dev.fitbit.com/build/tutorials/examples/
Another beginners tutorial, a "Hello World" http://drrea.org.au/Fitbitstuff/minimaltute.pdf
and another
Best AnswerWasnt sure where best to put these tutorials? At Github at Fitbit /ossapps ? Request a Tutorials heading or under examples? Then do a PR?
