Hi,
I need some urgent help here. When I make a oAuth2.0 call from the browser using the url as below,
I do get a response with a value to 'code' query string parameter, which I successfully use in subsequent calls.
https://www.fitbit.com/oauth2/authorize?response_type=code&client_id=XXXX&redirect_uri=http%3A%2F%2F... nutrition heartrate location nutrition profile settings sleep social weight
However, when I try to make the same call programatically through java code, I get a 403 error.
URL nurl1 = new URL("https://www.fitbit.com/login?redirect=%2Foauth2%2Fauthorize%3Fresponse_type%3Dcode%26client_id%XXXXX...
HttpsURLConnection conn1 = (HttpsURLConnection) nurl1.openConnection();
conn1.setRequestMethod("POST");
conn1.setRequestProperty("Content-Type", "application/x-www-form-urlencoded");
String authString1 = "XXXXX"+":"+"XXXXXXXXXXXXXXX";
String authStringEnc1 = new String(Base64.encodeBase64(authString1.getBytes()));
conn1.setRequestProperty("Authorization", "Basic " + authStringEnc1);
System.out.println("the response code "+conn1.getResponseMessage());
Pls suggest a way forward
@PalsN wrote:
Hi,
Can you private message me the non-redacted URL you were using?
