I am working on a prototype data collector for a research project. participants join the study using a web form. They have to agree to participate and enter a unique participant id sent to them in a separate email. The participant id needs to be forwarded to my redirect url so that we know how to map fitbit data to participants.
I am using the authorization api. I can get it work as long as I do not try and pass any extra data.
https://dev.fitbit.com/build/reference/web-api/authorization/authorize/ say there is some way to use query string parameter 'state' we can use to send extra data
This is my url
www.fitbit.com/oauth2/authorize?
response_type=code
&client_id=XXXX
&redirect_uri=https://www.XXXX.edu/fitbitWebAPISubscription
&scope=activity heartrate location
&expires_in=604800
&state=XXX-123
Any suggests would be greatly appreciated
Andy
I figured out how to make this work. Your form must use action="post". The action url should be the URL with the query string generated by the ?oath tutorial debug tool??? This uri has a query string with thing like scope, redirect_uri, ... It looks like your form can only have one input. the name must be 'state' . If you have other input fields they will not be passed to your redirect_uri. I guess you could use javascript to remove additional fields and concatenate all the values in the state.value
your subscribe get end point will be called . The 'state' query parameter will be passed in the query string
Hopefully this same other time future
Andy
Best AnswerI figured out how to make this work. Your form must use action="post". The action url should be the URL with the query string generated by the ?oath tutorial debug tool??? This uri has a query string with thing like scope, redirect_uri, ... It looks like your form can only have one input. the name must be 'state' . If you have other input fields they will not be passed to your redirect_uri. I guess you could use javascript to remove additional fields and concatenate all the values in the state.value
Andy
