12-24-2016 09:32
12-24-2016 09:32
Hey,
Now that we can see battery percentage on the Charge 2 is there any chance of returning this from the device endpoint instead of Empty, Low, Medium or High.
Thanks.
Best Answer12-24-2016 12:39
12-24-2016 12:39
@Bonxy That's the battery indicator, it won't have a percentage. Battery percent is not returned in the device endpoint; only empty, low, medium, or high.
Best Answer12-24-2016 13:10
12-24-2016 13:10
I know its the battery indicator. But you must be getting them levels back when it syncs.
Thought you might have changed it to the percentage number at some point.
Best Answer03-09-2018 23:43
03-09-2018 23:43
they can definitely see battery %. I had a problem with mine, and helpdesk was able to confirm it was stuck at 90%.
Best Answer03-22-2018 14:40
03-22-2018 14:40
agree - here's what my Alta reports via the API:
'features': [],
'battery': 'High',
'lastSyncTime': '2018-03-22T11:26:21.000',
'mac': '1234567890AB',
'batteryLevel': 100,
'type': 'TRACKER',
'id': '123456789',
'deviceVersion': 'Alta'
Best Answer03-22-2018 14:49
03-22-2018 14:49
so if the % is returned by the API, then there's a potential business opportunity here for someone with the right skills ... a standalone android widget that just displays Fitbit battery % !!
Best Answer03-22-2018 16:32
03-22-2018 16:32
remember it's the data as of your last sync - so if your fitbit doesn't synch automatically (like most people, it seems) the data is old and possibly invalid.
Best Answer03-22-2018 16:37
03-22-2018 16:37
fine by me .... better than nothing ... the battery symbol ( empty, low, medium, high ) in the app is only as relevant as the last sync anyway ... only today my battery was medium 1st thing this morning, and when I synced in the afternoon ( I don't autosync to save battery ) it went down to low ... I'd have much rather seen that it went from 28% down to 21% ... I'm guessing that low is <25% .. medium is 25 to 75 and full is > 75% ... so showing the full symbol for 2 days running is misleading in itself!!
