10-22-2014 17:25
10-22-2014 17:25
Our servers currently make ~900k calls to your api each day. Yesterday I deployed a code change to switch the protocol to https. We don't have any errors, but I noticed our throughput fell significantly after the change. Wireshark shows that we're recreating the SSL connection on each request, which creates significant overhead for your servers and ours. I imagine this will be magnified in two weeks when you require all clients to use SSL.
Does your API support connection reuse? Should we be using that?
Best Answer10-22-2014 17:29
10-22-2014 17:29
Yes we do. If you care about the performance, then absolutely you should make use of it.
Best Answer10-22-2014 17:34
10-22-2014 17:34
Thanks for the quick reply!
I can have one of our developers make the change tomorrow. Do you have example client code using the ruby oauth gem or Faraday?
