02-18-2015 03:24
02-18-2015 03:24
Hi,
When a user logs an activity by pressing the start button and stop button on the Charge HR device I don't see this activity returned from https://api.fitbit.com/1/user/activities/date/{1}.json in the activity section like events tracked via the fitbit app e.g.
{"activityId":52001,"activityParentId":52001,"activityParentName":"Yoga","calories":162,"description":"","duration":1800000,"hasStartTime":true,"isFavorite":false,"lastModified":"2015-02-05T10:30:40.000Z"
,"logId":xxxxxxx,"name":"Yoga","startDate":"2015-02-05","startTime":"09:00"}
Is it possible to pull the activitys logged via the Charge HR device?
Thanks
James
02-20-2015 01:50
02-20-2015 01:50
It would be good to get an answer to this...
02-20-2015 03:12
02-20-2015 03:12
We're also having issues with this - any information from FitBit?
Best Answer02-20-2015 09:34
02-20-2015 09:34
Thank you for reporting this, we are notifying the appropriate internal team and beginning to investigate the issue.
Best Answer02-20-2015 10:09
02-20-2015 10:09
Hi James,
The activities logged from our Charge, Charge HR, and Surge devices are not currently available on the api.
Best Answer02-20-2015 10:48 - edited 09-23-2015 09:42
Currently, the Get Activities endpoint only returns manually logged activities that override tracker data. We will be adding activity logs that effectively annotate tracker data to the API by end of Q4.
Edit: updated ETA
Best Answer02-23-2015 01:20
02-23-2015 01:20
Does the tracker data exist on a different API?
Best Answer06-02-2015 08:42
06-02-2015 08:42
Hi Jeremiah,
Just wondering if the tracker data has been added to the API yet?
Thanks
James
Best Answer06-02-2015 11:33
06-02-2015 11:33
The data from the device is currently available. See the Get Time Series and Get Intraday Time Series documentation. The activity/exercise logs (start/stop time, activity type, etc) created on the device are not yet available in a list form. The logs themselves do exist if you know the id (Get Activity Log), such as looking at the URL in the Fitbit web app. (This will be improved. It's just not released yet.)
Best Answer06-09-2015 02:05
06-09-2015 02:05
Best Answer06-29-2015 04:14
06-29-2015 04:14
@JeremiahFitbit wrote:Currently, the Get Activities endpoint only returns manually logged activities that override tracker data. We will be adding activity logs that effectively annotate tracker data to the API by end of Q2.
Hi Jeremiah,
You mentioned that work outs logged via the ChargeHR start/stop button would be added to the API by the end of Q2 can you confirm is this still the case?
Best Answer09-23-2015 07:00
09-23-2015 07:00
Hi,
Also looking for an update to this topic. Thanks.
Best Answer09-23-2015 09:42
09-23-2015 09:42
We will update the topic when we have something to announce.
Best Answer04-18-2016 02:47
04-18-2016 02:47
Any Update on this topic ?
Best Answer04-18-2016 08:41
