05-04-2016 11:01
05-04-2016 11:01
We've experienced a high number of repeat requests for a single user today that's causing us to hit the rate limit for that user. Our logs are showing posts from Fitbit to our subscription endpoint 1 - 2 times per minute every minute for the last ~4 hours with update notifications for the same user. Each request contains the same 4 dates to update in the range of 2016-01-13 to 2016-01-17.
When we GET the activity endpoint for the user there doesn't appear to be any updated data there.
GET: https://api.fitbit.com/1/user/-/activities/date/2016-01-14.json
Can you provide any insight into what might be going on here?
The request body looks like this:
[ { collectionType: 'activities',
date: '2016-01-14',
ownerId: '<owner-id>',
ownerType: 'user',
subscriptionId: '<subscription-id>' },
date: '2016-01-17',
ownerType: 'user',
date: '2016-01-13',
ownerType: 'user',
date: '2016-01-15',
ownerType: 'user',
subscriptionId: '<subscription-id>' } ]
Best Answer05-05-2016 12:09
05-05-2016 12:09
I responded to your private support ticket.
For anyone else interested, this was caused by a device not properly syncing.
05-04-2016 13:53
05-04-2016 13:53
Have you check to see if this user is genuinely adding manual activity log entries on those days?
Sometimes people use third-party data import apps into Fitbit that backfill their data from other sources.
Best Answer05-04-2016 15:53
05-04-2016 15:53
No manual entry activities were ever returned as part of the user's summary data. The subscription updates (now finally stopped) were sent every minute or more (until the rate limit was hit) for ~7 hours in total which doesn't seem like normal update behavior. The updates were always for the same 4 dates as well.
The only data I can see changing are the tracker distances data. For example, here are 3 responses from the /user/-/activities/date/2016-01-14.json endpoint a few hours apart. Notice how tracker distance goes from 4.64 to 10.29 and then back to 4.64.
4 May 2016 10:21:16
{"activities":[],"goals":{"activeMinutes":30,"caloriesOut":2855,"distance":8.05,"floors":10,"steps":10000},"summary":{"activeScore":-1,"activityCalories":1134,"caloriesBMR":1927,"caloriesOut":2798,"distances":[{"activity":"total","distance":4.64},{"activity":"tracker","distance":4.64},{"activity":"loggedActivities","distance":0},{"activity":"veryActive","distance":0},{"activity":"moderatelyActive","distance":0},{"activity":"lightlyActive","distance":4.64},{"activity":"sedentaryActive","distance":0}],"elevation":42.67,"fairlyActiveMinutes":0,"floors":14,"lightlyActiveMinutes":255,"marginalCalories":578,"sedentaryMinutes":1185,"steps":6700,"veryActiveMinutes":0}}
4 May 2016 12:20:07
{"activities":[],"goals":{"activeMinutes":30,"caloriesOut":2673,"distance":8.05,"floors":10,"steps":10000},"summary":{"activeScore":-1,"activityCalories":1030,"caloriesBMR":879,"caloriesOut":1745,"distances":[{"activity":"total","distance":10.29},{"activity":"tracker","distance":10.29},{"activity":"loggedActivities","distance":0},{"activity":"veryActive","distance":7.05},{"activity":"moderatelyActive","distance":0.24},{"activity":"lightlyActive","distance":2.99},{"activity":"sedentaryActive","distance":0}],"elevation":118.87,"fairlyActiveMinutes":3,"floors":39,"lightlyActiveMinutes":123,"marginalCalories":692,"sedentaryMinutes":140,"steps":11922,"veryActiveMinutes":55}}
4 May 2016 13:16:45
Some sort of sync loop maybe?
Best Answer05-04-2016 18:05
05-04-2016 18:05
Please send your client id and the user id to us privately to investigate more.
05-05-2016 12:09
05-06-2016 11:00
05-06-2016 11:00
Thanks Jeremiah. We'll add some additional logic on our end to deal with the situation.
For anyone else that finds this thread, a few takeaways:
